Raceco’s advice on tapped clearances for EV era bikes is useful. The factory settings are to compile with noise regs.
From the Raceco website
Tappet clearances for two and four valve engines
Two valve engines
Tappet clearances for the Guzzi big twins should be set to 0.20mm for the inlet and 0.25mm for the exhaust. This also applies to the “modern” Guzzis such as the Sport 1100, Cali 1100i and V11. The factory settings for these bikes are 0.10mm and 0.15mm respectively, but this is to try and reduce engine noise to meet US emissions regulations. With tappets set this tight the engines have trouble ticking over and running cleanly at low revs.
