I’ve just taken the Cali III FF out of it’s winter lay-up.
I was well pleased when it started up first try then less pleased when I checked it over and found fuel leaking out of both the after market fuel tap and the filter.
The seals In both items had softened and perished due to the effects of the ethanol content of the fuel. I immediately checked the internals of both carbs but fortunately the Frost fuel stabiliser I used had done its job and there was no corrosion of the metal parts. Unfortunately it doesn’t claim to protect elastomers.
I have replaced the tap and filter and changed the flexible pipes for R9+ rated bio fuel proof material.
Let’s hope that keeps the problem at bay for a while.
Last year I had to trim back a carb float pivot tube as it had swelled and was sticking. Ethanol strikes again.
At the moment we’re only getting E5 but we’re due to move to E10 in the near future so Lord knows what will happen then.
