So having spent ~6 hours trying to bleed the linked brakes i have decided to take a break and seek the knowledge on here. Le Mans 1 with fwd and rear pipe manifold splitter only, no proportional valve.
So here is what I have done …
1 Bled the front using a vacuum bleeding tool, nipples both side.
2 Then bled the rear.
3 Had an issue with suspected air being drawn in via the nipple threads so I greased these.
4 Repeated the front - then the rear, etc ad nauseam.
5 No matter how many times I have tried the lever refuses to pressurise the system.
Before assembly I have fully serviced both calipers with new seals ring, besides if there was an issue here I would have fluid leaking from behind th pads and dripping down the wheel / brake disc. All four pads / pistons are fine.
I serviced the master cylinder with a new piston & seal kit. I pre-greased this with the brembo assembly silicone grease and all went together smoothly and immaculately clean after a session in the ultrasonic parts washer.
I’m using DOT4 fluid, which is quite thin.
So I have now dismantled the master again. It and the pistons, old & new, have been back through the cleaner.
The barrel of the master is clean and shiny, and no scratches that either my wife or daughter can feel with their fingers (my sausages ar too fat !). I can see a grey area to the top of the barrel that might be a small depression about 10mm before the reservoir hole, and about 10mm in from the front diameter step so about where the rear lip seal would sit.
I intend to try another re-assembly and repeat the bleeding exercise.
I have read that using a syringe to push the fluid up to the reservoir is more effective, so i will try that. What volume syringe do I need to fill a caliper and purge to the cylinder in one go ?
Thanks for reading.
