Lazy post:
Any one know or can point to the lengths of the brake lines on a G5?
I could measure but won’t get to my garage for a week or 2.
Rear MC to splitter; splitter to rear caliper; splitter to front left caliper (one line, losing the solid pipe); Front MC to right front caliper - G5/ Small Cali bars.
Have used Goodrich buildaline in the past which are really good…
I recently ordered new lines for my Spada from Furore products back in the lock down. You would be best to go and measure them as you will need to specify the various ends to suit, banjo, male union, female union and varying angles. My handlebars are probably lower than on your G5 so the front brake will need to be longer.
I retained the rigid pipe under the tank.
https://furoreproducts.co.uk/custom-brake-hoses
This is my order, but I strongly recommend you make up your own shopping list.
1 x Custom Brake Hose (0.1m - 5m) Brake splitter to rear caliper.
- Length in mm (to nearest 5mm): 520
- Hose Colour: Clear
- Union 1 Thread/Size: M10x1.00
- Union 1 Type: Male swivel
- Union 1 Bend Required: Straight
- Union 2 Thread/Size: 10mm Banjo inc 2 x copper washers FOC
- Union 2 Banjo 10mm Colour: Stainless
- Union 2 Bend Required: 5-70 degrees
- Union 2 Bend - Enter value in range selected (nearest 5 degrees): 15 Custom Brake Hose (0.1m - 5m) £24.84 £24.84
1 x Custom Brake Hose (0.1m - 5m) Linked Front brake from rigid pipe under the tank to front left caliper.
Length in mm (to nearest 5mm): 840
Hose Colour: Clear
Union 2 Thread/Size: M10x1.00
Union 2 Type: Female swivel
Union 2 Bend Required: Straight Custom Brake Hose (0.1m - 5m) £26.28 £26.28
1 x Custom Brake Hose (0.1m - 5m) -
Length in mm (to nearest 5mm): 720 Front brake right.
Hose Colour: Clear
Union 2 Bend Required: Straight Custom Brake Hose (0.1m - 5m) £25.74 £25.74
1 x Custom Brake Hose (0.1m - 5m) Master cylinder to Splitter.
- Length in mm (to nearest 5mm): 500
- Union 1 Thread/Size: 10mm Banjo inc 2 x copper washers FOC
- Union 1 Banjo 10mm Colour: Stainless
- Union 1 Bend Required: 5-70 degrees
- Union 1 Bend - Enter value in range selected (nearest 5 degrees): 40
- Union 2 Bend Required: Straight
couldn’t ask for more
You’re welcome, Copy and paste is great
This is for a Spada so probably got lower bars than your G5
I have retained the rigid pipe running under the tank from the splitter heading to the front left caliper.
