Went to drain the pipe that hangs below the gearbox, it’s got a plastic bung in it, looks like water comes out, not a lot, about a tablespoon, ended up with the pipe coming away from somewhere tucked up behind the frame, anybody know where that end goes?" … Is it from the airbox ?..don’t want to remove the tank just to find out it doesn’t!..V11 Breva.
Not to worry…found it, it’s from the airbox ![]()
