BREVA 1110 instrument cluster
Is it a reasonably straightforward job to take apart the cluster to repair the glass?
From memory, once the fixing screws are out you need to press in and release several little plastic tabs around the edges, used a small (2.5mm) flat screwdriver on mine. Worth drilling a couple of small drain holes in the lower corners while it is apart.
