JUST CHANGED FRONT TYRE ON THE BREVA TODAY , PUTTING WHEEL BACK ON AND JUST WONDERING HAS THE TYRE FITTER LOST A WHEEL SPACER AS I ONLY HAVE ONE, HOW MANY SHOULD THERE BE? ANY HELP WOULD BE APRECIATED THANKS IN ADVANCE CHEERS
one spacer (9) according to the parts diagram the other side is spaced with the spindle
The spindle has a long shank on the non threaded end. This acts as the spacer on the disc side. You should leave the spindle clamp at the bottom of the fork loose while you tighten the spindle nut. This will allow the fork to locate itself stress free. Once the wheel is torqued up, then tighten the spindle clamp on the fork.
THANKS GUYS FOR THE HELP
Please don’t type in capitals.
