Anyone here broken the so called ‘quick connector’ at the pump on a Norge or whatever, and if you did what was your solution.
Yes i have…
Yes i have…
I think gutsibits sell them!
I think they do but my prob is getting the old one out, was hoping someone on here had done it
In that case get the gutsibits one, then buy an in line quick disconnect fitting and fit it into the fuel line, that way you don’t break it the next time you remove the tank!
Thats plan A, part ordered, plan B would be to find a suitable metal fitting and tap the plate to fit it
Plan B would be the solution I would take, but I can make a fitting and tap out the plate,
But if you fit a inline quick disconnect fitting, why would you ever need to use the original one, it’s fit and forget!
