After recently having the side panel off, after investigating an electrical fault. I unscrewed the brake fluid reservoir, bit of sediment in there!
Did the front right brake using a hose with an incision it it with the open end blanked off, no problems.
Front left… couldn’t get it to pump through.
Got out the big guns, Mityvac . Should have done this at the start.
So easy, didn’t do the rear, it’s beer o’clock.
Do it tomorrow.
