I’ll be changing the oil filter soon, looking at the sump gasket, does it stay in place when fitting the sump to to the crankcase? Is there a useful tip at all?
Grease both sides is the top tip.
Second tip is don’t forget the 4 inner bolts holding the sump on.
Love and kisses
theone&onlymin
x
I stick them on with a thin smear of grease often you can use the old one as it usually stays in place, but have a spare if you don’t you are bound to tear it
Regards Keith (great mines think alike )8 Valve Eagle2013-04-17 20:02:29
Some with sump spacers need 2 gaskets
Hmm, the filter I took out was date stamped.99 If I was an optimist I would say it was NOS. Bike has 27,000 showing on the clock. Right back to work, replaced both sump & spacer gaskets. Now to torque the thing up, assuming I can find the correct torque value somewhere.
Can’t find anything, 10Nm sounds good A gentle tighten before going for it though.
I always use a large jubilee clip tightened around the oil filter to prevent it loosening ( As they have been known to do ) with catastrophic results! http://motoguzzimaintenance.wetpaint.com/page/Moto+Guzzi+Metal+Stone+Oil+Change Shame not to when you have the sump off.
DazGuzzi2013-04-20 17:15:46
Agreed. Although more likely a potential problem with a broadsump ‘trapdoor’ filter change. Plus always double check the sump gasket is on the right way round!
guzzijack2013-04-20 17:12:38
I meant the sump bolts, not the oil filter.
I just usually tighten it ‘that much’. Just so it won’t fall off. Also apply a diagonal tightening sequence.
PS: the screws are only going into aluminium so you can’t put too much welly on them.
yes, I didn’t go for the 10Nm, stopped before that.
Rule of thumb; tighten until either the thread just strips or the bolt head shears off, then back off half a turn.
