Normal
0
false
false
false
EN-GB
X-NONE
X-NONE
MicrosoftInternetExplorer4
I have A 2005 California EV ( Hydraulic valves)
The other day I decided to oil the control cables.
The fast idle cable I disconnected from the lever end.
The throttle cables I disconnected from the capstan on the throttle assembly and the twist
grip.
All Oiled and replaced The bike started as usual.
Went for a 70mil run next day all running fine but the idle
would not fall below 1400 to 1500 RPM.
At a friend’s I slackened off the opening cable but it made
no difference so left till I got home.
At home took off the throttle body covers and had a good look
round all items were on their stops I disconnected all the cables but it made
no difference ( There was plenty of free play any way)
Now read the manual as I hadn’t much idea of what did what.
Found the idle speed control screws on my throttle body’s they
run up from underneath.
with engine running I screwed the right in and then the
left, then engine gave a slight cough
and stopped.
Good I thought I just back them off 1-1/4 turns and see if I
can adjust the idle speed .
But now the bike won’t start. It cranks fine but doesn’t fire or even attempt
to.
I left it a day or two but no difference, I disconnected the
ground on the battery for a time, reconnected
but made no difference. I have checked
all local connections all seem sound on switching on the ignition the pumps
runs up and then stops.
I invested in one of those programs you put in a laptop to
try and read any fault codes, but all that’s done is mess up the lap top.
I am in Devon so no Guzzi dealer nearby and as the bikes not
running so will be difficult in getting
to one.
So Anyone have any ideas as to what to look for?
I have also posted in General a request for recommendations for
a diagnostic tool or program suitable for looking for faults and keeping the
bike in tune.
So any advice will be very appreciated.
Regards Bill
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:“Table Normal”;
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-qformat:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:“Calibri”,“sans-serif”;
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-fareast-font-family:“Times New Roman”;
mso-fareast-theme-font:minor-fareast;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;
mso-bidi-font-family:“Times New Roman”;
mso-bidi-theme-font:minor-bidi;}
