Caliper bolts
Hi all. Can anyone confirm that the caliper to fork bolts are M10 x 1.5 as one has stripped and I am going to helicoil repair. It is a le mans 1000.
Hi. That is correct. I have a Timesert insert kit that I used when I had one stripped on my Harris Bonneville. Where abouts are you?
Thanks Don. I am in Leicester.
You’re just up the road from me, I’m in Market Harborough. You’re welcome to borrow the repair kit which comprises of a drill bit, a tap and some inserts. This is a far better repair than a helicoil. I’m retired so am about available most times. I’ll message you my number so you can give me a ring to sort it out.
Thanks Don. That’s very generous of you. Got your message OK. Will give you a bell later.
