Hi,
I have just purchased a set of MG urban panniers, how or can you match the pannier key to the ignition key so only one key for all ?
i know for the metal cases, matched barrels are available from mytech to have the top box and panniers use the same key (not the igniton key but i dont want that anyway).
who makes the urban cases?
I’m not sure if this is any help, but the V100 comes with two extra key barrels specifically for fitting to the MG panniers. Could yours be the same?
Hi Thanks for the reply.
I did look but it seems that’s just for the Mandello. Definitely none under the seat of the V85TT.
No big deal in the end but it would be nice if it could be done
Hi DB100, I purchased a second hand V85TT travel E5+ just over a month ago and it came with 2 spare pannier lock barrels for the urban panniers, I’m in the process of replacing the lock in the Guzzi Tank bag (handbag ?) with one of the spare barrels, involves a bit of fiddling making a new lock tab, but I hate having more than 1 key. So they should be available from Guzzi, you will need the key/lock number I would imagine.
