Hi All,
I have an interesting (to me at least!) question and thoguhts about why the V50 has such small (24 mm) standard carburettors. I’d be interested to know if anyone has put larger Dellortos on, with the standard airbox and got a great result?
The background:
When the Moto Guzzi V50 was introduced, it was used as an Italian Police motorcycle, and there is a school of thought that it was detuned to cope with the rigours of high usage. It has a relatively high (for the time) compression ration of 10.8:1, has an over-square engine (74 x 57 mm) - and therefore should be able to take higher revs and consequently produce more power, as Power = Torque x rpm. But it only produced 45 to 48 bhp (depending which source of information you use).
Dellorto’s Guide to the choice, setting and use of tapered-needle motorcycle carburettors gives a graph for determining choke/carb size. It states that for a two-cylinder engine, take the bhp, divide by 2 (the number of cylinders) and read off the graph to get the range of ideal choke size. In the case of the V50, if we say it produces 45 bhp, the graph suggests the user should be looking at a carb size of between 28 and 34 mm. Being towards the lower end of this should give better pick-up at the expense of outright power (and vice-versa).
What are your thoughts on the above? Is there a reason for continuing with the 24 mm carbs, over say, the 28mm carbs?
