I noticed an empty thread on my Griso swing arm. Looking from the reverse side there are two bolts top and bottom and in between these there is an empty thread.
I have a photo but not sure how to upload.
It would be appreciated if someone could let me know if there should be a bolt in here.
You can either rest easy or we both need to worry as mine is exactly the same!!
You’d think they could put a plastic blanking plug in or something if it’s not meant to be used.
Thanks for the reply.
I had a strap wrap around my back wheel and damage the speedo sensor, so I had though it may have also taken out whatever should have been there.
So all is good, I just have to install a new speedo sensor now, which I know how to do as a previous one died due to water.
