Cardellino stopping the engine
Yes I know this is a silly question BUT how does one stop the engine on my 73cc Cardellino once started. Just in the final stages of a rebuild, on with the wiring and can’t see any means of cutting the engine !!
Hi Monty, put it in first gear and stall it. Don’t do this with the brake light activated or it will blow the bulb. If I remember correctly this is all mentioned in the owners manual. Hope this helps, Cheers Phil
Thanks Phil. This seems bizar to me. Surely there must be a better way (pull the plug?)
