Hope this doesnât happen to you ⌠I wrote this up in a previous issue of Gambalunga.
In 2017 tried to start the Norge high up on Glenshee but every attempt was met with an âInsert Codeâ message. What code? The service code (which you use to get rid of the spanner icon after a service)? No. I tried that.
What the bike was looking for was my (well, the previous ownerâs) personal security code. I did not know this. Why was this happening? It seems that the keys have a coded chip but do not have a battery, as with some car keys. According to Pete Roper, who knows a great deal about Guzzis: âThe ignition switch has an inductive coil in it. When the key is turned on the coil produces a magnetic field sufficient to produce an EMF that will cause the chip in the key to broadcast its code. This is detected by the antenna that surrounds the lock barrel and it sends a message to the dash saying go/no-go.â From what I read later, if you buy a new bike, youâll be prompted to set the user code every time you try to start the bike. This message only goes away if you set the code. This also means that if you start a Griso, big Breva or Norge, and do not get such a prompt, somebody has set the user code and if you plan to ride the bike, find out the code before you ride off!
It turns out that if you only have one key, or only have one key with you on a ride, you cannot get round this problem, unless you know the User Code. Trust me to discover this on top of a Scottish mountain.
If, for any reason, the chip is not detected, the dash displays âInsert Codeâ. This is not the same as the service code! Reasons behind this might be (after a lot of web searching and discussion): Corroded battery terminals, a dodgy oil pressure switch, a bad connection to the fuel pump relay or a bad connection of the main multiway connector to the ECU. The weirdest reason, offered by Serena Powis, is having the bike parked too close to a radio or mobile phone mast (this apparently happened to a club member and I found a similar reference on a bike forum, in this case not a Guzzi.).
So, how did I get the Norge back down the mountain? Magic ⌠voodoo ⌠serendipity, call it what you will. After moving the bike (see the radio mast comment above) and disconnecting the battery for a few minutes, I was still stuck. In the end, I called Carole Nash and arranged a recovery. Half an hour later, as I waited for the truck, two guys walked up to the bike âOh, a Guzzi - I just bought a Griso and have a 1000S in the shedâ. I explained my problem and turned the key to demonstrate ⌠and the dials swung round and it started! Why? I do not know. Anyway, I cancelled Carole Nash and got home safely. There was a dodgy moment when I realised that Iâd locked my gloves in the top box which meant that I had to turn the engine off to unlock it â but it restarted and behaved from then on, all the way home to Dorset and has done, touch wood, since.
Back home, I followed Pete Roperâs info on a forum and reset the user code. This method will only work if you have the original pair of keys. If you donât, youâll go though some pain getting new keys and even then you are not home and dry. Here is the procedure (provided you know the code or are not required to enter it):
Insert the first key and turn. Wait for the needle swing. Using the joystick button on the lefthand side, click and hold for a couple of seconds to move past Trip 1 and Trip 2 to âChronoâ. Click the joystick to the right until you see âMenuâ, then go to âSettingsâ. I initially went to âDiagnosisâ and had to enter the Service Code (28315 for my Norge). This may not have been necessary as I had to return to Settings to find the option I needed. So, in Settings, look for âCode Recoveryâ and select that. You should be prompted to insert a new code. Use the joystick pressed to the right to increment the first digit of your new code. When happy, press and hold for a short time and you can enter the second digit and so on. Finally, press and hold again to enter the new code. Now, youâll be prompted to insert the second key. At this point my heart sank as I had to turn everything off to remove the first key! All was well, however, as the second key went in, and the new code was accepted. Forum users seem to go for â11111â or the last five digits of the bikeâs VIN, the relevant service code (so the two codes are the same) or some other memorable number. Record it â write it down!
So, the upshot is, if you buy a used Norge, big Breva or Griso (not sure if this applies to every CARC bike), check to see if you get the invitation to set the User Code when you turn the key. If you donât, ask the seller what the User Code is set to. If they donât know, and the bike has two keys, you should be OK but reset the code as soon as you can. If the bike has only one key, Iâd walk away. It could prove very expensive if the ECU throws an error. I have never, ever, seen this mentioned at all and it took quite a bit of web searching to work out exactly what to do. Caveat Emptor.
