Console warning light 850 T4
Hello All,
Can someone please let me know what the lower centre warning light is on the the instrument console?
It’s the one below the battery/charging warning light.
I can’t find mention of it in the Haynes manual.
Thank you.
Picture? If round and red: low (rear) brake fluid. Commonly, the reservoir top with fluid level sensor and contacts is absent, making this light redundant.
Hi Barry,
It’s the lowest light on the console, red and rectangular.
see brake pedal symbol! and as per my previous comment.
Usually connected via a red/yellow wire to the rear brake reservoir switch as Barry suggests
mainly used on the g5 and convert models!
I couldn’t work out what that symbol represented - now you’ve pointed it out, it’s obvious!
Thank you.
