Can anybody suggest why a Convert my friend has purchased isn’t pulling properly? The auto box oil seems to get over hot and the bike loses drive. It apparently had new gearbox seals 2 years ago and a new oil radiator core.
We have checked out what seems to be the usual suspect – the hex drive to the ATF pump, and all seems ok. The spring on the pressure switch is 5mm shorter than the 38mm long it should be and there is a spacer missing. We will sort the pressure switch out and also install a pressure gauge and he will replace the oil with AeroShell 41.
Thoughts? Perhaps the torque converter has just had enough at what appears to be 60,000 km?
