It’s a bit of an odd request but if anyone has a dead pump they’d part with I’d be grateful. The reason is that I think I may have a solution to the problem of the broken barbs if the securing ring is also broken i.e. you can’t use the R-clip fix. I don’t even really need the pump, just the plate that is held in by the big ring on the back of the tank where the fuel line and power connector plug in to.
