Dead? Fuel solenoid
After soaking the inlet in Starbrite fuel tank cleaner for a couple of days (I’m getting continuity between the electrical connectors) but the valve doesn’t open. I should admit the bike’s been standing a few years, so I can expect many gremlins. Instead of replacing with a standard fuel tap & sleeving the outlet, I’m thinking to simply drill out the valve so there is a constant supply to the fuel pump. Has anyone else tried this, or does anyone have any comments?
Hello McFuzzi
What year and model is your bike?
Best wishes Chris
Hello Chris, it’s a 2000 Jackal.
Update: I’ve detached the tap from the solenoid & found a very rusty plunger. Wire brushed & now soaking in white spirits. We shall see…
Ethanol in fuel attracting water
Russell
& neglect! It’s now covered in Bilt Hamber de-ox gel. I’ll give it another day or so & if it doesn’t come to life with 12v I’ll adapt a Le Mans tap.
