I’ve been wondering about the de-cat pipes that I see on sale, primarily how you’d get through an MOT, as I presume the test will check emissions don’t exceed the Guzzi original design spec to comply with the ‘construction and use’ regulations?
I’m dreading to see how the V100 exhaust box survives a winter as it doesn’t look that robust compared to the stainless steel ones I’m used to, which is what got me to thinking about options.
I think the cat box IS stainless, it just discolours when it gets hot. The main issue is the weight hanging off that stupid bolt which is only anchored at one end, coupled with the vibration.
There is no emissions test in the MOT for motorcycles and I’ve got a feeling that for reg 61 Construction and Use Regulations, motorcycles are classed as “exempt vehicles”, though not sure on that one.
Cheers Speedy. I’m no engineer so it may be my terminology but the manifold box under the bike definitely doesn’t look ‘stainless’ to me compared to the shiny confections I had on previous bikes, it’s manky already after a few summer months, hence the doubt about winter. Just to check we mean the same thing it’s labelled number 1 on the attached diagram
As for Reg61, I’m not sure either as the Gov website on motorbike MOTs says the test will check that the exhaust is ‘secure, complete and not too noisy’ Motorcycle parts checked at an MOT - GOV.UK.
Your guess is at least as good as mine regarding whether the absence of a Cat would mean the exhaust system was ‘incomplete’. One way to find out, but it could be expensive!
Hi again. Yes the cat box is “stainless” it just discolours easily. It doesn’t actually corrode as such. There was a very similar material on my last FJR 1300.
As far as “completeness” goes, it just means that if the system was designed with headers, collector and mufflers, they should all be there. Only no-no is if the system is marked “off road use or race use only”.
There again, peeps have been known to put stickers over these, as the tester is not allowed to remove them…
Bit like the cops in Amsterdam ( Jules & Vincent conversation in Pulp Fiction…)
I’m seriously considering fitting a decat system as the cat fitted is so ugly and for something supposed to be stainless looks really cruddy. Corrosion resistant maybe but surely not 316.
it does get a bit tatty looking in winter, but so do the mistral header pipes if you ride all winter like i do the big benefit is the engine runs so much better and doesnt feel like it’s being held back.
riding modes actually do something after decat, with it on they are barely noticable apart from the traction control being more aggressive in rain mode. throttle response in sport mode is noticably sharper now.
Should be an old post somewhere about of mine. Covers the Chinese v Mistral de-cat, pro’s and cons as well as the current situation regarding mot rules and modifications to the exhaust system. We compared the system side by side with the standard set up.
I’m considering the Mivv decat exhaust pipe for my V100 2024 Wind Tunnel. The pipe doesn’t appear to have a threaded port for the O2 sensor which is mounted on the downstream side of standard cat unit. The Agostini system seems to have a port for this O2 sensor from the pics I have seen. Does anyone here have experience of this issue and how to resolve?
