ECU and Dash Fault codes
I have got my 2014 Norge all back together after a complete refit/overhaul, on start up the service light stays on. I have gone into the set up and cleared the service light, but it comes back on again. On checking in the menu, one set of lights in the dashboard errors has 2 crosses through it, would anyone have any details on what these all mean please?
Thank you.
There are two sets of codes, one for the dash errors and one for ecu related ones.
You may find that these are dash errors for the fuel pump and air temp.
Depends on the error code.
Hi Brian,
Do I need a reader for the error codes?
The dash ones can be accessed from the dash board, you will need to enter a code to access that area (you use the trip reset button on the handlbars to do this and navigate.
Guzzidiag will give you the Ecu errors, which you can clear using Guzzidiag.
Thanks Brian
