Engine Oil for Breva 750
Hi,
What engine oil is most suitable as a top-up for a year 2003 Breva 750?
I use Motul 10/60 fully synthetic. 10/60 is the Guzzi recommended grade for the bike, I believe it was different originally and then they changed it to 10/60.
Alex
Thank you. In addition to Motul, are there any other recommended brands?
I use Mobil 1 10W-60.
Good oil. Reasonably priced. Check out Opie Oils.
Hi, a couple of questions please:
  • How does Putoline N-TECH® PRO R+ 10W-60, compare with Motul, Mobil and Castrol?
  • Is Putoline N-TECH® PRO R+ 10W-60 suitable for the Breva 750?
Hi, any advice on the Putoline please. Thanks
personally i use the oil i can afford which comes from my local car shop. I really don’t think that the brank makes the least difference these days
