Can anyone tell me if a Spada seat will fit onto my le mans?
It is only for occasional pillion use so I can take my wife for a ride out.
The dual seat rear pad is rather small…
Thanks for any help
Technically, most Tonti fittings will exchange between models, but - for example - the Spada seat might fit to the frame, but will it snug up nicely to the Le Mans tank? So often this boils down to “suck it and see”.
The Spada seat hinges up on the grab rail. I’m not sure if that would fit over a Le-Mans mudguard?
This picture might help.
Thanks guys for the replies. I’ll have to borrow a seat to try out. Looks like quite a few models will fit the frame, then maybe it’s up to me to trim the seat to suit the fit against the tank of my MK2 Le Mans
This might give you a bit of an idea how they compare, my old Le-Mans 2 and my Spada. The Spada tank looks to be a bit longer.
Hi Don, I think it is deceiving as I think the Le Mans seat dresses up further on the back of the tank than the Spada.
Looking at both model’s parts lists I assume that the back of both tanks fixes to the frame cross tube in the same place and both with a similar rubber stap so I would think that they must be the same length.
