Seem to be accumilating issues here, I have noticed two or three occassioms now that the harzard lights on my V85TT flash briefly on starting the bike, then go off. I initially thought I may have hit the hazzard button by accident but this isn’t the case, is this some sort of warning situation? it does not happen all the time.
cheers in advance
Hazards come on with the “urgent service” warning. What does the eagle do in your tft screen (bottom right) when the hazards flash? That’s where the fault/service warning appears.
My guess is the Ecu is picking up a fault situation that somehow clears itself within a few seconds.
It a 24 new model, never noticed the eagle but no other warning lights are on. Again it’s intermittent, doesn’t happen on every startup but it has happened at least three to four times now.
Just had it back to the dealer for the clutch to be adjusted as it refused to find neutral.
As I said I thought it was me catching the hazard button which is directly below the start button, however they flash quite rapidly then stop by themselves. I will call the dealer today
Just a guess, but possibly ECU is detecting Voltage drop on start-up, but only sometimes. Be interesting to see if it stored a DTC for it.
