Has any one changed the top bush on a tonti fork leg ( one just below the oil seal)
Got a bit of play in the one leg
Not sure if the T5 is the same, but my Spada had no bushes in the legs. The stanchion just runs in the ally lower leg. Mine was slack when first assembled dry. The advice of others on here was that the movement would go away when the oil went in and it did. No discernible slack once it was all back together.You could have a check of the parts list to see if yours does have a bush.
thanks Don, got conflicting reports of a bush in my legs
Gutsibits have a part number for a 38mm t5 bush, but stein dinse say no bush!
Will have the front end off over the winter and see
