Noticed last night that the forks on my t5 pull together about 1mm when the spindle is fully tightened
Wondering if I’m missing a small spacer ? I only have one large tubular spacer on then right hand side of the wheel
dought very much if they would of put a spaccer in that is only 1mm thick
spacers can be different made my own for the v1000
There’s meant to be slack between wheel bearings and the internal spacer, Guzzi and others don’t always machine for it very well! If they are all too tight then they will wear fast, and that might explain fork legs being too close?
