I am moving my Cali 3 over to cast wheels. I was going to use the spacer off the wire wheel front axle when I noticed there are different part numbers for the spacer depending on cast or wire wheel. The wire wheel spacer has a length of 18.5mm. Can anybody confirm for me what the length of a front cast wheel spacer is. Cheers
Mine has 29mm visible from the inside face of the fork leg to the face of the oil seal. Sorry, I’m not taking the wheel out to determine how far it goes into the seal to reach the bearing face!
Thanks for checking it out - at least I know the wire wheel version doesn’t fit and what approx length I need when I give the Guzzi breaker a ring tomorrow. Thanks again you have been most helpful.
