If like me you’re very nervous when disconnecting the “QD” fuel pipe fitting under the tank on your modern Guzzi then this is good news.
http://gutsibits.co.uk/pr/TheShop/index.php?q=fuel+pump+spigot&f=d&Model=0&search=SEARCH
at £25 i dont think so:
http://www.apriliapartsbuyer.co.uk/parts/pegaso-650-ie-2001-2004/fuel-pump-cpl/ap8104192-coupling
still too expensive for a bit of plastic that will break again.
AP8104192
also see:
http://www.v11lemans.com/forums/index.php?showtopic=16766HaydnR2012-11-21 00:04:50
Are you sure the Aprilia part is the same Haydn? If you look at the thread on Guzzitech I linked to originally you will see that a metal alternative can be used.
[QUOTE=Brian UK]
Are you sure the Aprilia part is the same Haydn? If you look at the thread on Guzzitech I linked to originally you will see that a metal alternative can be used.[/QUOTE]
I’m not certain that it is the same but I would think more than likely. I keep meaning to contact/visit John Guest, they must only cost pennies to produce. The brass fitting is definitely the best solution.
HaydnR2012-11-21 18:07:44
