Just cleaning the sump out, so checked out the pressure relief valve, haynes manual shows ‘seating disc’ (item 18) above the spring. No sign of this, or of any possible shims, as are mentioned in the haynes text. Has anyone else noticed the absence of these?
No issues prior to removal, only way to check is with a pressure gauge i guess…
