I have been restoring my 56 Galletto 192 but need help with info on Ignition timing setting, points gap etc. I also need the torque setting for the head and cylinder nuts.
Any advice would be greatly appreciated Phil
Do you have access to the manuals? Unfortunately they will be in Italian, but you can read the pictures and translate text with Google Translate on your phone
Manuals should be available here
https://www.guzzitek.org/gb/accueil_gb.htm
or here
https://www.rpw.it/Documentazione.htm
I have all the Italian ones and a translation of one but there doesn’t appear to be any info on what I need.
A lot of the other info you can as you say work out.
Thank you very much
This is a link to the user manual that has an illustration of setting the points, so probably has the text to go with it Page 40
Thank you very much, I am sure I can work it out from there.
Thanks again much appreciated Phil
