Gear & Brake Pedal bushes
If you have a 1995 on Cali (and others I suspect) with the plastic lined metal bearings on the brake & gear pedals and the gear bell crank then these are a straight swap
Actual name is a Glacier Bush AFAIK
Location
Guzzi Ref
Bearing Boys Ref
ID
OD
Length
Linky
Gear shift Bell crank
30252060
GB1215DX
12
14
15
http://www.bearingboys.co.uk/GB1215DX_Split_Bearing_Bush-17040-p
Gear/Brake Pedal
30678160
GB1620DX
16
18
20
http://www.bearingboys.co.uk/GB1620DX_Split_Bearing_Bush-17051-p
Price from these people (no link blah blah) just over £7.00 for the set of 4.
Enjoy
Tris
PS you don’t always see a significant improvment when fitted, but that’s not the bushes fault just Guzzi apparently being unable to machine to a tight tolerancetris2012-03-13 08:32:10
Sweet, I paid seven bloody quid just for one brake pedal bush a month ago, I’ve now ordered a set of four for thirty nine pence more!
Keep up the good work.
Ooh nice find. Betterer links…
very fast service and good prices, only thing is the bushes for the Cali EV gear change linkage were fine but as I have the Advanced Brake Pedel fitted which uses a bigger size bush I will have to measure the size and order one , the biggest job with the gear change side was removing the old bushes but a lot of heat did help.
So does the ANIMAL technique of a small screwdriver and a hammer to fold them in on themselves
Thanks guys, just what I needed. ordered some.
Easy website to navigate. Thanks for the original post. Lots of other bits I can replace on the T3 from this site.
For older T3 cali I have ordered 2 of these for the bell crank which is 32mm long. I will put one in from each end.
http://www.bearingboys.co.uk/OB121616_Plain_Oilite_Bearing_Bush-3676-p
For the gear lever mount (heel and toe type) and the brake lever mount, 1 each of these.
http://www.bearingboys.co.uk/OB162020_Plain_Oilite_Bearing_Bush-3714-p
Ordered them this morning, as the later california ones mentioned above in the first posts, don’t fit. I will post the result here later in the week.
Sorry about the scrappy links.
