Hi to all.
Hope this finds everyone well.
I want to change the gearbox oil and the shaft drive oil for my 2000 Cali Special 1100 ev. Is it the same oil for both? If so, any recommendations. If different what grade should be used in each.
With thanks
Russ
this is for your Cali 1100? it always helps to offer the model, so ‘same bike’ owners can offer firsthand advice.
Yes it is. Sorry, completely missed it out.
Hi Russ
Have a look in the manual for the recommended grade. I tend to stick with the manufacurers advice as they tend to know best. Here is a link to The Guzzitek that has most manuals available.
https://www.guzzitek.org/gb/accueil_gb.htm
With thanks. ![]()
Will have a look.
Russ
Yes both it is 80/90 I have also put some Molyslip in the gearbox as well.
Thanks mate. ![]()
