Hi there I am considering some heated grips for my 2010 Stelvio does anyone have any recommendations for suitable grips as I’ve heard Guzzi ones aren’t that good cheers Tim
I use Oxford wraps over grips…they aint bad…
Just fitted R & G ones in time for the summer ![]()
They are too hot on setting 5 but nice on 3. Maybe if the air temp was about zero setting 5 would not be too hot!
I use these on a couple of bikes - I prefer them as you can retain the OE grips.
http://www.windingroads.co.uk/shop/product.php/116/symtec_heated_grip_kit
Wraps are for the enlightened
I have a set of those supplied by Windingroads on my Griso, they work well and are very neat.Â
Ha…thats me Kev…not…if I was enlightened I’d still be riding a UJM…
I had to stiffle a titter as heated grip has a different connotation in the highlands…
careful, stffling your titters can get you locked up south of Berwick ![]()
Phil
edit: I used a set of snowmobile heated elements under the foam grips on the 1100 and Oxfords on other machines.
Hi Tim,
I have just fitted Oxford Adventure grips to my 2011 Stelvio. They work well but are a bit of a pain to fit. See the Stelvio/Breva heated grips post.
Yours,
Richard
