Hydraulic lifters
Not sure if my 2005 Cali Stone has modified valve lifters. I have removed the rockers and note that the “adjusters” have an 11mm nut on the end and nothing to fine tune the clearance. One of these nuts was loose.
  1. I have seen pics online showing hydraulic lifters with no threaded adjuster, would this mean that mine has been modified?
  2. Is there a process to reset the loose adjuster?
The original rockers are blanked off. The recalled modified rockers were set using using some form of shear nuts/screws.
You’ll need someone more knowledgeable than me to help with the setting process, but at a guess, as long it is set comfortably within the range of the hydraulic, “bullet”, the hydraulics should take up any slack.
Davy
Thanks Davy. Just checked again and the screw head is sheared, so the mod must have been done. I have tightened the loose nut as far as I can manage with a standard spanner. It looks about the same as the one on the other pot, but hopefully someone can clarify the correct process.
