Ignition switch.
Hi all, my ignition switch seems to have gone bad and is very hit and miss.
Does anyone have one they would sell me?
V1000 Convert. (Tonti framed bike) I’m after an original bullet connector one if you have one in your stash you would like rid of.Thumbs Up
Cheers John.
Hi John
Options in case you can’t a Switch with the bullet Connectors!
https://www.ebay.co.uk/itm/358203428849
Regards, Nik
The bullet connectors themselves could be dodgy, guess how I know … :slightly_smiling_face:
This was on the LM, they were working, but in a bit of a sorry state, and loose!
You can take the switch apart by very carefully bending the tangs outward at the base. Things to look for:
  • corrosion or dirt on the all of the copper contacts
  • wear on the copper in the base. If you’ve got a dip here then it’s bye-bye time
  • loose bullet connector sockets. These can be fixed by pushing a thin screwdriver behind them to tighten up the gap
  • corrosion in the bullet connector sockets and on the bullets themselves.
As you are contemplating buying a new switch, you don’t have much to lose by stripping the existing one.
Hi, I suddenly had a brain wave! I am restoring a T3 California (Slowly!) so I disconnected the switch from its loom. Guess what? It is a spade terminal one! I modified my loom and fitted it, after a good clean and it felt much more positive in its action. Turned the ignition on and no difference in the result. The problem was, at first, my charge light was not working, then the oil light too. Then the lights refused to work! The oil light started to come on when I wiggled the key, Hence the dodgy switch theory. All was well before, and I can’t think of anything I have touched that might have caused these failures. Investigations continuing when I find time. Thanks for the replies.
If you have the old style fuse box with Euro Fuses - give them all a wiggle in the holder and make sure they are clean and seated well. Its amazing how many odd faults can be traced to the fuse box on older big blocks. Especially true if the bike has been standing for a while.
Also clean and reseat the 18 pin and 15 pin connectors that connect the main loom to the clocks and LH switchgear
Russell
I have checked the fuses but not the multi plugs so will give them a look and a probe, thanks.
