I want to install a relay on my V7ii Special ABS. The purpose is to have a live supply to which I can connect auxiliaries such as SatNav, USB socket, heated grips, etc, in the knowledge that when the ignition is off, then all these auxiliaries will be off too. No unneeded parasitic drain on the battery.
I have had a look at a wiring diagram kindly supplied by “This Old Tractor” at:
This shows two potential connectors that are ignition controlled. They are No 11 (Pre-installation Gps) and No52 (Pre- installation USB)
I have found and used No52. It is actually 12v, not 5v. I have attached a USB socket to it and used the USB socket to charge my phone so that I can use it as a SatNav. (When I had the USB socket attached to the battery direct, it did cause quite a parasitic drain. It made made starting the bike after a week or 10 days a slightly anxious affair !!)
My question is: will this wire connector at no 52 be sufficient to activate and maintain a standard automotive 12v relay when the ignition is on ?
Any thoughts or advice on this would be much appreciated.
