Luigis faux pasMachine: 1100 SportiIssue: to fit the clutch lever arm you need to move the swinging arm and / or the sub frame to get the clutch lever arm into position between the tangs. The clutch push rod and swinging arm clearance is insufficient to allow it to be mounted otherwise.Solution: Mill a bit out of the pivot point area to allow the arm to slip over the clutch push rod without removing half the rear end.Bad word rating: Mild *******| Incandescent rage
Mad Farquhar2012-05-12 14:56:06
