Le Mans 1000 brake rotor bobbin washers
I stripped the brake rotors during the rebuild and need a new set of spring finger washers and circlips for the semi floating rotor bobbins.
I can not find the parts on Gutsibits or ebay. They are simple consumable parts and should be readily available as they are not specific to Moto Guzzi.
Could someone kindly advise a UK based company or individual that could supply these parts. - or perhaps a fellow member has too many spares, some of which he is willing to sell on?
I need 15 of each part in total for the 3 rotors.
Many thanks .
Try Simply Bearings, they have a good stock of circlips, not sure about the fibre washers.
I’m considering converting my Le Mans III to floating stainless steel discs that are offered by HMB, I see HMB also offer new brake disc bobbin’s on their web site, hope this helps.
Cheers, Don.
