Need a Little end bearing for a 73 cc Cardellino, any idea’s ? Or do I need to get one made ?
Try GuzziRetro. Marco has most parts for those motorcycles.
Cheers Phil
Cheers Phil, I’ll give it a try.
If it is just a bush within the con rod then any decent engineering place that does lathe work should be able to make one quite easily out of phosphor bronze.
I’m not sure where you are, but one company that comes to mind is Seager engineering https://www.seager-engineering.com/
