Hi,
I’m setting the static ignition timing on my Eldo. WHich mark on the generator ulleu wheel should I be lining up with the mark on the engine casting?
There are 4 marks, If rotating clockwise from the front, This Old Tractor site says use the 3rd mark, Chilton’s manual seems to suggest the first mark.
Hi if you go back on thisoldtractor and under workshop manuals find “the shade tree mechanic” manual. I’ve used this to do the static timing and when I service the bike always worked good for me.
Cheers Ian
I do mine with a strobe. I generally set it to achieve correct full advance, which comes out a little bit more than the book value at idle.
I don’t think they are too fussy though.
