My Mandello has recently started to run hot when in traffic, I cannot hear the cooling fan kicking in with the engine on or off. Is this an issue and is it easily resolved. My service provider is 3 hours away so any advise would be appreciated
Check plug to fan motor and plug from the temp pick up. for damaged pins or corrosion.
If you find which way the sensor switches the fan circuit (closed when hot or when cold and switch to earth or between wires) you can check that one.
thank you I will give that a go
After blowing all its coolant, the bike is now with the dealer who reckons it has blown the thermostat housing. I trust the dealer but was just wondering if anyone else has had this happen to them.? The bike is 2023 and low mileage, Is it possible that being stuck in the queue at the channel tunnel for 2 hours in 32 degrees could have help cause the issue? Thanks
It will be interesting to hear the cause. As a blown thermostat housing sounds like effect rather than cause. Unless they mean cracked which has caused bike to loose coolant then overheat due to that.
No issues here. I’ve had the bike in traffic at 42deg C here . Fan was on constantly but checking app data after showed it kept it at 98-100 degrees. So for sure being in traffic shouldn’t cause a failure. Obviously if its stationary idling in 32 degrees then turing it off to just give it an easier time is best option.
I have heard of early bikes having cooling issues though. Water pump failures or hose clips causing leaks.
