Many many parts available. My brother and I have inherited a large collection of parts from my deceased father. He had bought the remaining stock from Chris Clark when they shut down, so there are many NOS parts available along with several disassembled bikes.
I will be slowly working my way through the lot, identifying parts and listing them as I go. I will do that here and also on FB marketplace, then finally ebay.
I am more than happy to look for specific parts, feel free to send me a direct message. Generally speaking, parts are early 70s - early 90s.
Everything is located close to Bridgwater in Somerset and I am happy to post or meet at events / swapmeets.
This thread will be updated as I go…
Pair of original plastic LM2 side fairings in blue, good condition, a bit dirty. 50
NOS LM2 plastic front mudguards in bronze. 25 each
(I have pictures of each of these but for some reason I can’t post them)
I could use a couple V50ii parts. Have you got headlamp bracket rubbers to fit on the fork legs and a Brembo, round front master cylinder?
Im in Frome so not far from you.
Ha! Ignore my separate reply done before I read this! You are seriously off and running!
In the post message dialogue box there is an icon of a computer with an arrow above it pointing up
Click on the icon and select the photo you would like to post, click on the open button and it will load your photo unless it is too large to upload. If it is too large reduce the size of the image file, I use Microsoft Paint to do this, but other software is available!
Best of luck Chris
Oooh. What small block parts do you have? Or more usefully, parts for which small block bikes? I’m just west of Taunton so Bridgwater is good for me…..
any california 1100i parts?
e.g. shocks, ecu, clocks, drive shaft/bevel box ?
Thanks chris, that’s what I thought but it seemed not to work for some reason. I will try again.
Hi steve,
Definitely got a master cylinder. I will have a look for bracket rubbers. Please send me a DM and I will respond as soon as I have been able to have a look.
Al
Mostly v50, but some V65 also. Nothing for new V7
Possibly. What are you looking for?
Have you got a rear M/C for LM2? Also need LM 1 type front indicator mounting bar and fairing/mounts/headlight. Any chance?
Do you have any 36mm carbs as well?
PM me.
S23
Anything for a cali 2? Always on the lookout for spares. Ta.
Side panels? Pannier frames? Carburettors? I’d consider buying anything for the bike if the price was right of course.
I have definitely seen some panier frames, however I don’t know who the manufacturer is. I will check tomorrow.
What size are the carbs needed?
Alex - Hi - If you come across any V65TT parts I would be interested - especially side panels Cheers
