Hi Folks.
I’m going round in circles trying to resolve a starting issue on my 2006 Norge.
The other day when I went to start my bike, I hit the starter button, nothing happened not even a click sound, but the engine warning light came on as did the service caption on the screen.
I did all the usual checks, battery spot on, all the solenoids also ok, removed the starter, its was not jammed or stuck and tested OK. put it all back together and hit the started button same as before no click sound, and the engine warning light came on as did the service caption on the screen.
I then disconnected the starter solenoid starter cable, added a cable so I could fire the starter motor with out using the starter button Started first time no engine warring lights. I connected the starter solenoid starter cable back up and back to no click sound, and the engine warning light came on as did the service caption on the screen.
I connected a OBD and used the Moto Guzzi diagnostic tool, showed 3 codes.
P0130 Lambda sensor (left): to high
P0201 Injector left :to high
P0170 Starter switch ELECTRICAL ERRORS: to high
Has anyone dealt with anything similar?
