Got back after a decent run into Dorset, on the last few miles
home started to hear a mechanical noise each time I pulled in the Clutch. The bike
and clutch all working O.K.
At home I investigated further.
All is normal until I pull in the Clutch. Once in there is a
mechanical repetitive clunking chatter.
It appears to be from the transmission end of the engine
more pronounced on the near side.
I take it, it would appear to be a clutch problem? which must
be an engine out job?
Any ideas as to what it might be and advice on best course
of action would be appreciated.RegardsBill Dag
Hi Bill
Clutch access is a matter of both wheels and swing arm out. Battery tray off and loosen engine mounting bolt. The frame them tilts forward to give access to the gearbox. There’s a bit more to it but that’s basically it.
FWIW My EV developed a distinctly Ducati rattle when the clutch is pulled in. This started about 5000 miles ago and doesn’t seem to affecting things too much.
All the best
Might just be cos the plates are loose, BUT problee a good idea to check out the thrust bearing at the back of the gearbox, might be failing, seized whatever. Has the amount of lever adjustment play changed?
small block clutch is different to big block clutch . small block is single plate , big block ( on older models ) is twin plate , hence the rattle when lever is pulled .
Does it sound like the ball in a roulette wheel when you turn the engine off ;-)I’ve had that problem on my LM4The centre had ripped out of the back clutch plate and had slid back and was free wheeling around the gearbox input shaft !It didn’t do any damage at all but I reckon I only rode it about 10 miles like that.The clutch and every thing worked fine other than a lot of free play at the clutch leverPics save a lot of wordshttps://www.flickr.com/photos/124005478@N05/14971603416/in/set-72157646299972178/
The clutch adjustment can also make a difference if it isn’t clearing properly, but as mentioned above, check the lever linkages first as that is a lot easier than going inside the gearbox.
