Greetings
I am a new owner and member, recently bought a new Norge and am delighted with it except … I am vertically challenged and find the sidestand a bit of a stretch.
I hadn’t noticed that police models had a different side stand.I modified my sidestand in two ways. First of all I welded a larger plate to the foot to stop it just sinking in to hot tarmac. Then I welded a length of rod to that, bent up a little. This enables me to hook it more easily with my heel. Also easier to put down too.
I hadn’t noticed that police models had a different side stand.I modified my sidestand in two ways. First of all I welded a larger plate to the foot to stop it just sinking in to hot tarmac. Then I welded a length of rod to that, bent up a little. This enables me to hook it more easily with my heel. Also easier to put down too.[/QUOTE]
THAT side stand look similar to the one fitted to the V11 Le Mans it has the wire type kick tag on it easy to use I wonder if the V11 Le mans/sport side stand would therefore fit easy?
Thanks Guzzibear - will try to investigate - could be a cheaper option if it fits and there is a second hand one available - I don’t have easy access to welding/brazing gear to go down Brian’s chosen route.
Sounds like good advice Guzzibear. I had a look at the current Cali sidestand at the NEC show yesterday and although it is similar pattern the mounting is much more heavy duty than the Norge. I don’t know if the previous models are the same but no doubt the dealers you mention will. Cheers.
Contacted nice helpful guy at Reboot who went off to investigate but unfortunately got back to me to say the Le Mans def does not fit as it’s a different mounting. Looks like it’s either grow another inch on my left leg or fit the £80 jobbie. Will let you know how I get on in case there are others like me…
i have a great long side stand looks home made its come with a load of bits i have bought
willing to post it to you for you to play with if its suitible price can be negotiated
pm address if required
