I have carried out a service on my norge and everything appears to be okay
But; the service notification and red triangle is lit
Has anyone any idea how I can reset the service notification?
Bernard,
Select MODE on the dashboard selector, scroll down and select DIAGAOSTICS. You will need to INSERT SERVICE CODE (which for my Breva is 36421; you’ll need to Google for your Norge). Then scroll down to and select RESET SERVICE.
I wrote the service code and my personal code under my seat - never know if I might need it out in the boonies.
The red triangle may go away after you start it. Disconnecting the battery for an hour or so may remove it when the computer reboots.
You may have forgotten to connect the air temp sensor ?
thank you hopefully I’ve got it sorted out
