Evening my 2007 Norge has a side stand switch issue can anyone enlighten me as to where I might find the connector in order to replace it with a new on, my guess is its buried somewhere up behind the fairing or under the tank anyone able to narrow the search down a bit before I remove half the panels off the bike in order to locate it ?
Thanks in advance
When I had a 1200 Sport, from memory the connector was quite close to where the switch is located, the switch would not be made with very long lead.
I think I still have a bypass to eliminate the switch so I could still use my motorcycle until I could get a new switch.
It seems to have a long lead with a heat proof shield on it that disappears up into the centre of the bike somewhere there’s no connector near the stand, I also have bypass for it, great minds think alike
