2019 V85 owned from new, 34,000 miles. Lots of mods to exhaust and intake.
Serviced by me about 800miles ago. On startup from stone cold the oil pressure sensor alert flashes up for a second or so. It didn’t do it at immediately after the service but a month or two later - say 250miles (it’s winter ok) it’s lighting up most times I start straight out the garage. For the rest of the day it’s fine.
Oil sight glass is completely opaque now but rudimentary home made dipstick suggests oil is midway-to-top when cold. It’s more likely overfilled than underfilled as I made a pessimistic dipstick.
Options seem to be 1. oil pressure sensor although this was replaced as a warranty thing way back. 2. I did something weird when replacing the oil filter (I’ve a left over O ring which I think should go on the oil filter cover, although I’m sure there was one there). 3. The oil filter is crappy and falling apart of something even weirder. 4. The oil pump is failing somehow = impending financial and mechanical disaster.
Any other thoughts or experiences? I will whip the switch out tomorrow give it a clean and see how that does.
